By damper, I'm talking about a little strut that mounts on the strut tower and bolts to the motor to stop it from moving. The only one I've found so far is for the 2J and is made by Weapon R.
Adam
Adam
Don't bother with the damper, just run solid motor mounts.honestabe said:I know I can feel my motor moving every time I shift while boosting. They help save your motor mounts and also help put the power to the ground.
Adam
honestabe said:Vibrations increase wear which decreases reliability.
Adam
becauseican said:BIC to the rescue.............the prototypes are done, just testing them......
Dylan JZ said:Awesome.. Pics or, Description?.. I'm curious to see if you used shock tower mounts or if you went a different route.
foreverpsycotic said:I hope it doesnt mess with my STB
