who else is running a hx35??
black89t
boost'en down 101
Oct 27, 2007
951
humboldt, ca
so am i the only one who loves these turbos? im running a 7 blade hx35 off like a 01 cummins and its been a great turbo for me. i have it at 18psi and it moves pretty good. haven't got it on a dyno because there isn't one for hundreds of miles and it runs great from just street tuning it. im sure there has to be other people running them lurking around and i would like to hear how its performed for you. also if you've dyno'd it what did you make. heres a pic of mine. :biglaugh:
scottiedawg66
Bay Area Ca
There is a nor cal supras dyno day on jan 12th in west sacramento. You should come findout where you are at. Good times good people, and i predict a 4 digit pull from the 2jz foxbody mustang.
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
I'm running one as well at 17 psi, mine was bored out with a 62mm billet wheel from Driftmotion though. It pulls really hard. I love these turbos, but haven't gotten it to the dyno yet
*not sure why the pictures uploaded blurry but can be viewed on my buildthread
Sent from my PC36100 using Tapatalk 2
black89t
boost'en down 101
Oct 27, 2007
951
humboldt, ca
yeah i prolly wont be able to make it. but out of curiosity where is it happening? theres a shop here thats finally getting a dyno. they should have it in a couple months so if anything i'll find out when they do their opening.
nice! so the larger wheel is working fine with the stock exhaust housing or did you switch it? and what year of truck did your hx35 come of?
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
Runs great with the stock exhaust housing, full spool around 4400 rpm. I think its off a 98 cummins
scottiedawg66
Bay Area Ca
here is the location of the dyno day. I know it is far for you, but I figured i would at least let ya know! It starts at 10:00 on the 12th, and there will be bbq. If you have never attended a nor cal supra meat you are missing out.
Evil Genius Racing, LLC
2214 Rice Ave.
West Sacramento, CA 95691
black89t
boost'en down 101
Oct 27, 2007
951
humboldt, ca
hmm thats seems like pretty late spool im gonna have to look exactly next time i drive my car but i think mine hits early :dunno:
2214 Rice Ave.
yeah sadly ive never been to one. maybe this year i'll make it out! im sure its pretty fun
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
I think I'm running a 14cm^2 housing, whatever the stock one is. Plus with the bigger wheel it will definitely spool a little later than a stock Hx 35
black89t
boost'en down 101
Oct 27, 2007
951
humboldt, ca
yeah i think mine has a 12cm on it. whatever the 7 blade ones came with. i know the older 8 blade ones flow less and have a larger exhaust housing so maybe you have one from a early 98.
black89t
boost'en down 101
Oct 27, 2007
951
humboldt, ca
Was doing a little street tuning and made a video of a pull. I guess mine doesnt really hit till 4000 in the lower gears. but if im in 4th or 5th in spools earlier cause all the load. That's at 17psi with 255/40/17 re11a's air down to like 30psi. These tires have great grip and hook really well. All seasons or 200+ tw tires just spin :biglaugh:
http://m.youtube.com/watch?v=DA7XTK443HM
7M4EVR
695
fah, fah away
Except hes running with a broken temp gauge on a 7M. Thats one thing I personally wont do. Especially when a new water temp sensor is like $10
black89t
boost'en down 101
Oct 27, 2007
951
humboldt, ca
thanks! my motor has a new temp sensor on it so im thinking the gauge in the cluster itself broke but haven't bothered to fix it yet. and yes i have a aftermarket gauge. also its on a na-t 2jz ;)
black89t
boost'en down 101
Oct 27, 2007
951
humboldt, ca
scottiedawg66;1981836 said:
Oh damn! I thought u had a 7m for some reason. What fuel and ecu are you running?
california 91
7m ecu with lex/550, afpr, and a safc2
idk how you guys didn't notice in the picture of my engine bay that its a na-t 2jz
destrux
1,183
10
PA
I got mine on ebay for $300. It was a rusty POS, but the internals were nice. Took some soaking and hammering to get the housing off to rotate it (you have to).
I had an HX35W, but it was too big for my purposes so I swapped to the HY35W. Slightly smaller, spools earlier/faster, I think it would support about 475whp. I'm only running mine to 370whp right now. Hard spoolup around 3250rpm though, and response above that is very good. Still feels sluggish below 3K, but what 1JZ doesn't?
FWIW, the "W" means the turbo came with an internal wastegate. I welded them shut on both of mine since they're setup for a low RPM diesel engine and are not large enough to control the turbo on a high RPM gas engine. I use a 50mm external gate.
HX35W
HY35W
HY35W dyno results:
black89t
boost'en down 101
Oct 27, 2007
951
humboldt, ca
suprarick;1982587 said:
where did you all buy your HX turbo's? I've been trying to find some but no luck!
diesel forums or ebay. and the 7 blade one is the best
destrux how much boost are you running to make 370 out of curiousity?
