I'm having problem with my supra in the mornings it takes a bit longer to start.The engine has been rebuilt and recently changed the valve cover gaskets cuz there was oil in the spark plugs. I'm running rich as well and I got the tps adjusted. The mechanic told me to get a new idle screw cuz mine is bad. The idle stays at 900-800 rpms and it moves a bit up and dowm. I was going to check the cold start injector. The supra hesitate a bit.
There's no vacumm leaks, no oil leaks, no antifreezer leaks. It smokes even when the car is in neutral.
