white smoke coming out of exhaust radiator resevoir overflo
SUPRAY
hi quick question, was wandering if this is a bhg symptom white smoke coming out of exhaust, coolant resevoir overflow...pls advise :1zhelp:
mkiii222
Troy, MI
If it's a ton of smoke then it's most likely a bhg.
On the way home when I blew mine I was blowing enough smoke to look like a James Bond style smokescreen(poor guy on a ninja got behind me at one light, didn't see him after the light turned green).
CSquared
Atlanta, GA
When the headgasket BLOWS there will be a ton of thick white smoke. Personally i've never heard of white smoke coming out of the res. but to each their own i guess. ha. If it were just coming out of the exhaust i would say make sure you dont get your colors mixed up. Seems like a lot of guys on here mistake oil smoke for being white. But since thats not the case... you get the idea.
Best bet if you want to know is to get a block test. Any of your local shops will have one or you can buy one but theyre pretty pricey. Does the car overheat or have you been hearing any wierd gurgling sounds from behind the dash when the start the car in the morning?
best of luck guy... blown headgaskets suck.
