I'm bored and getting paid to look this up for you LOL, plus you are also from Canada and had the ambition to put a 7M in a 4runner
In a 1990 Toyota Supra, the manual transmission R154 has a reverse switch on the side of the transmission case.
The red with black wire leads to the taillamp harness and connects to the 2 back-up lamp bulbs.
The yellow wire comes from Junction Block #3 Pin B14, and is supplied by the fuse box, and the relays etc etc.
Should be a simple and and out as long as:
Power gets to the switch
Switch opens in R gear
Power makes it from switch to bulb holder
Bulb holder makes contact with non-burnt bulb
Bulb is properly grounded
hmm..it seems the that on the truck its the same as the car. there are 2 wires on the side on the tranny. i have found those, and yes one is for the 4wd (transfer case), the other one as i mentioned is on the side for the reverse. but there are 2 wires, assuming both go back to the driver/passenger side back up lights.
so say if i splice into the 2 wires going into the side of the tranny and splice into the junction box ## b14 it should work right ??
and which one is the junction box #3 ? is it the huge connector,meduim connector or the smallest one.
thanks for looking it up man, atleast your getting paid for it.
