Which valve spring compressor?
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
I've never seen on that will work outside of a Toyota shop. Many folks have borrowed the tool from their local Toyota shop, actually.
I personally made something work - a big C clamp and a small piece of plastic plumbing pipe that I dremeled a slot out of to get needlenose pliers into. This method only wprks if the head is off the block, of course.
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
Head is off the block, I need to make something work, otherwise Im sittin here waiting until next week now.
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
Wasn't there a trick for that using two pieces of PVC pipe? I've read about it before, but never in much detail.... details would sure as hell help me out tomorrow.
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
my neighbor had a well, 8 ft lon piece of 1" wide pipe, I cut out a section to use pliers for the locks, and this is what we do...
One guy presses the pipe over the ratainer and compresses the spring, 1 lock is already in and sets in place, while its down I place the other lock in place, let up, it locks, were set.
gixxer750
2jzget comingsoon!
Mississippi
I used a piece of conduit with another piece bolted onto it. One was a lever, the other was a short piece with a slot cut in one side. Used the cam cap holes with a bolt...
CRE
Oct 24, 2005
3,485
Denver, CO
So I presume to remove the keepers all you need to do is stick a magnet down the pipe opening?
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
if you got snap on truck just get it off him it will be in the book they give you all the toy tec here use them makes life easy but i think it cost about 250 buck's or some thing
i wish i knew the part number or just call toyota and ask a tec they must have one
there all so is another way to do ti as well i call it the getto time comsuming way unbolt cam and repeat
