I agree with Piratetip. That said, I run Red Line MTL in the tranny and when I had the LSD ran either Toyo fluid in the pumpkin or RL gear oil and added the FoMoCo modifier to taste. Other options are possible, such as MT-90 in the tranny. I'm not all that familar with RP products so you might want to check with them. It's just that the synchros in your tranny will work best when the right oil is used and LSD oils with modifiers usually hamper their operation. Whatever you use in the rear end be sure to change it once in a while. There isn't much in there and it takes a beating.
