which piggyback to use?
89Turbo7M
BLUEBULLET
Jan 12, 2008
120
area 51
i have an 82 celica supra w/ a 88 7mgte. i am currently trying to decide on which piggy back to use. the greddy e-manage ultimate or the maf-t pro. my question is has anybody had any exp. on woriking w/both units and what kind of concerns they had. the turbo has been upgraded to a 57 trim, head has been ported and polished, upgrade throttle body, lc-1 innovative wideband and hks boost controller.
Shima
I'v got Supra powers
May 23, 2007
215
carlisle
hey i demand a picture of the car :p.. but what else have you done to support your 57trim? injectors maf sensor fuel pump? or u running standard fueling? i am interested in this aswell. i was actually just going to fully replace my ecu with a stand alone unit. its the best way for tuning really. (or so i believe anyway) piggybacks are in my opinion a waste of time.
The1
Too poor to be here..:(
May 24, 2007
228
Austin, TX
I want a maft-pro but I'm so friggin poor, I have to just set myself up to save for it. But then again, I do want it with all the extras..
bountykilla0118
In Pursuit of 500rwhp
Jul 16, 2005
1,088
Atlanta GA
Piggy backs are good for what they are designed for in my eyes, which is for BPU cars with generally light upgrades like injectors and a bigger turbo, but are still stock internally and are aiming below 450rwhp.
Standalones are for people aiming higher than 500rwhp mark where they need to be able to tune at pretty much all RPM’s
Personally if you are just going for a quick street car and you want the most simple piggy back setup go for the SAFC-II, 550’s and lex AFM. If you have a bit more money to spend get the MAFT-Pro. It’s a great unit. It has some really nice features that a person who is aiming for higher numbers would find useful.
Plus if get all the MAFT-Pro feature you will actually save money I think for all the features of the MAFT-Pro its close to the $700 range but if you were to go and buy all the features by themselves you would spend over $1000
300 Boost Controller
300 SAFC
300 Wideband
250-400 VPC (Used)
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
So by those numbers, the boost controller and SAFC are almost as much as the MAFT-Pro with all the toys... Hmmm... Kind of makes it a no-brainer if you want both of those functions.
This is starting to sound like a better and better thing to me.
I presume that it can be tuned for larger injectors as well, making my Lexus AFM redundant...
bountykilla0118
Jul 16, 2005
1,088
Atlanta GA
I am personally running the SAFC. I already had the boost controller and lex AFM so for me it was easier and cheaper to buy a used SAFC-II to accomplish my power goals. I do believe the safc and lex afm have supported 600rwhp.
Dont take my numbers for fact search around first .....
89Turbo7M
BLUEBULLET
Jan 12, 2008
120
area 51
good info--but, which one is the easiest to tune for a beginner-novice tuner like myself. did purchase the map-ecu and found it totally confusing when trying to tune
89Turbo7M
BLUEBULLET
Jan 12, 2008
120
area 51
ok so i've decided to go w/the maft pro system--i've noticed that there are 2 diff units--the maft pro and the maft pro gen2--the gen2 is the upgraded version of the maft pro?,but is cheaper? what gives?
dbsupra90
toonar
indiucky
the maft gen2 is a second generation maft, which uses a gm maf sensor. the gen2 you cannot run speed density.
the maftpro is the only unit that you can run speed density (map sensor)
i've found wot tuning is very easy on the maftpro. the only things that take some effort are the boost controller (esp on an external wastegate) and the part throttle/response tuning. it has a few hiccups and quirks to it, and really takes some time to dial it in.
