Which oil is the right oil???
garrettrowe
Use the lightest weight you can that you're not burning up. On my old motor with 100K I was using 20w-50 and only burning up a negligible amount. That's about as thick as I would go though, and I live in Socal for reference. The motor would eat through a quart of 10w-30 in 1000 miles or so. On a broken in rebuild I would go full synthetic 10 or 5w-30
huntin5L
Niles, IL
yes my car eats up 10w30, i noticed it ate up about a quart also in 1,000 miles. Scared me there, it is the wrong oil im using.
P
PunaMKlll
Guest
take into concideration the temature u live in.Hotter climates will require a heavy weight oil. It can get hot here in hawaii and never cold so i run 20-50 synthetic on my n/a with 60K. but for your situation i would stay with base oil scence ur comming up on 100k. Using sythetic in your motor might bring about some unwanted leeks.
mkIIIman089
Ohio
15W-40 or 20W-50 full synthetic is what I would reccomend, I would reccomend against running the thinnest oil you can. I'm sure others will chime in with more of the same.
Personally I run Amsoil 20W-50 synthetic.
7MGTEJoe
Salinas, CA
It really depends on your climate. If you routinely operate your vehicle in freezing conditions you should run thinner oil. If you live in the desert you should be looking at thicker oil. Personally I use 10-40 in the winter and 20-50 in the summer but I live in central California.
Oper8or
80
Greenback, TN.
TurboSupra7 said:
well, i've been runnin 10 30 but it's starting to warm up here in Kansas city so i'll try out some 20 50
That is what I do here in Tennessee as well. During the cold months I run 10w30, during the summer I run 20w50. As for now.. its not running. BHG. It doesnt :beer: alot of oil. :) I got lucky on that.
