which mounts is the strongest? 2jz
nille__
22
sweden
hi, ive got both a pre89 crossmember and a 89+ crossmember. If i understood it right i should use either:
pre89, bic mounts, old style square motormounts
or
89+, 1jz brackets, new style round motormounts
right?
but if i have both. which one do you guys recommend? which is the strongest? i also have both trd 2jz mounts can i use them? i read that i can use them if i grind down the dowel pin. But they wont fit with 1jz brackets. tried it today.
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
i have pre89 xmember with BIC mounts and old square mounts. the square mounts are stronger due to the fact that they aren't liquid filled
PS its "are" not "is" LOL
The Reaper
Jan 10, 2006
1,909
Florida
yup
the 89+ mounts are smoother because they are liquid filled like jelly or something. but they tear easier
Evilempire1.3JZ-GTE
SF what a waste of supras
Jun 22, 2006
1,382
SoCal
I love the pre 89 more patch area of rubber less hitting issues with the aftermarket "Y" pipe and headers!
Less play in them and way cheaper then 2jz mounts!
Handles more HP just my opinion on them though.
kikwear002
174
Ft myers florida
custom mounts..break this
