i've been readin tons of archived threads bout 2jz swaps and i haven't been able to find out which clutch i should get when swapping in a 2JZ-GTE and using the 7M-GTE R154 transmission. i know i need the 1jz bellhousing so do i get a 7M clutch or a 2JZ clutch along with the 2JZ flywheel????
for now i want to keep the R154 until i can afford a new LSD diff, driveshaft and 6spd tranny. i'm not too mechanically inclined as to modigy shift linkages to make the V160 work. although i think i can bang the firewall a few times to get the stock twins to fit in
thanks
thanks
