I originally bought the Spec Stage 3, mounted it, stayed mounted for about 3 months then bought the RPS Max with the 3200 lbs. the RPS hold a lot more TQ (I believe rated to 625) which is around my goal, the spec was 520 tq but i believe it maxed out at 480 for someone here before it started to act up. I didn't try the spec pedal feel (since it was only mounted and never even used), but I can tell you that the RPS Max with the 3200 took me a lot of time to get used to. Very heavy for my liking, but holds like nothing else. for your power goals I would stick with the Spec stage 3 to be on the safe side and I believe both the stage 2 and 3 have the same pedal feel but don't hold me to that. see if anyone in your area has a MKIII with an after market clutch that is willing to let you drive the car or at least feel the clutch. I am in Orlando, FL, so if you are close by or you will be in town you are more than welcome to try my clutch.
