Which clutch is best for daily street driving?
VegaSupra
214
SoCal
My Supra is probably at about 300HP (give or take) right now, and I am not likely to go above 350-400 anytime in the near future.
Here are some clutch kits I've found. I've heard several members say they've had good experience with the South Bend Stage 1 kit.
Anyone have experience with Ralco, Spec, or any other brand that you'd like to recommend or recommend against?
Ralco RZ Clutch Kit - Stage 2 Carbon Kevlar $283.81
http://clutchflywheel.com/i-531754....gn=GoogleShoppingSeanNOFITMENT&adtype=pla&kw=
Spec Stage 1 Clutch for 1986-92 Supra Turbo $411.00
http://www.mvpmotorsports.com/templates/frmTemplateM7.asp?CatalogID=3082&SearchYN=N&subFolderID=306
South Bend Stage 1 1986-92 Supra Turbo $337.50
http://www.horsepowerfreaks.com/partdetails/South_Bend/clutch/clutch_kits/Stage_1/18487
customs
175
Edmonton Ab
I bought an ACT clutch for the supra. It was sprung 6-puck disc with stock flywheel and ACT HD pressure plate. It was awful. engagement was rough and it chattered and the pedal weight was awful. I personally dont have any other experience with those clutches you listed. As of right now I have a Spec Super Twin and it is amazing.
Some insight would be to stay with a full face sprung disc for drive-ability. Just like the clutches you have listed.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
I've used the more modified Spec units - specifically the stage 3, which was a 6 puck, and had good results with that. I wouldn't hesitate to purchase their stuff again.
I'm currently using a twin disc Clutchmasters, because I've gone well past the power handling capability of single disc units.
emiliorescigno
1,199
Woodbury, MN
I've used a SPEC stage 2 in the past, and I quite liked it. It's a full-face with nearly stock feel, I would have no hesitation daily driving on it. A good upgrade without going "too far".
With your power goals, I'd look into a SPEC Stage 2+ or 3+, both are full-face and hold more power than the 1 or 2.
gsxr141
1,158
10
rochester
has anyone had experience using an aftermarket disc with a stock pp? i saw somewhere that something like an act 6sprung 6 puck works well with the stock pp.
Suprapowaz!(2)
2,870
San Antonio, Tx.
I'm running an ACT sprung 6 puck with stock PP. It doesn't chatter much, but the engagement too quick for me. I have to bring the RPM'S up more that usual to try to slip it smoothly. That 6 puck is not designed to be slipped, and will start to chatter if you try to slip it like a normal full face stock clutch. I've done a best of 12.91 @109mph on that set up dumping it at 5200rpm. Hot lapped it before 5 runs straight and it didn't slip. I'd estimate that I was running 320ish rwhp during those runs.
In the past I had a Duralast organic full face clutch and PP that I put in because I was in a financial bind. Did a best of 12.89 @ 111mph on a different set up. It ran good its first pass down the strip, but when hot lapped it showed signs of slipping its second run. I'd guesstimate I was putting down around the same rwhp back then too.
If I could do it all again I'd find a full face ceramic disc with stock PP to run. I don't care for 6 pucks. I, too, will not exceed 400rwhp either.
gsxr141
1,158
10
rochester
good advice. i plan on hitting 400-450 wheel. i'd like a full face that can handle that much power. i was looking into act and spec, but haven't decided yet.
Zazzn
l33t M0derat0r (On some other forum) n00blet here
7
Toronto/SF Bay area
I'm running a Feramic 6 puck disk with stock pressure plate. Car made 430 whp and 435 tq on stock twins. Seems to hold up well but starting to slip now after about 4 years a several engines. Used the same disk to hold 635 whp on dual pressure plate.
Just asked a local clutch store to put Feramic material on. It's harsher than most though.
