use search function , been covered many times before. Most coil overs will allow enough drop. Good stance isn't just height though , it involves alot of factors , height , camber angle, OFFSET etc...
Most will only drop the rear to about the top of the tire tien flex included. That is unless you start messing with the spring perch height and shock travel.
Most fronts will go till the frame hits the ground.
Id stay away from the god speeds tho. And anything super cheap.
