So I ran the power from the cigarette lighter and the ground from a brown wire that runs to the left of the shifter. Will this produce inaccurate readings? I've read conflicting posts. Some state to run power and ground directly from the battery, others say to run 2 grounds and others say tap the power and ground from the ecu.
And of course, some people take the power and ground from anywhere. Which is the best route? I just wired the white 0-5v lambda wire into my AEM EMS and want to enable the auto-tune function to build some preliminary maps. Needless to say, I don't want to damage my engine with inaccurate readings.
What sayith you???
What sayith you???
