I got a 10x11 B&M cooler i hope to be installing this Friday. As of now i just my canton adapter and my permacool remote filter head. The cooler is pretty big and the only place i can get it to fit is under the driver side headlight. The outlet come out above and below the frame rail for the cooler. The filter will go either where it is now but higher or on the driver inside frame rail. Im not so sure on the thermostat. I have a shimmed pump but will all this be to much hoses? Will i need a check valve?
Now
cooler
possible filter location
			Now
	cooler
