Where to get a 1jz and prices?
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,584
Great Lakes State
I am looking to buy a 1jz tonight. i have seen many on ebay. They're 1000.00 with auto trans ecu and ignitor. Can I use the auto harness and ecu on my 5-speed different wiring?
Does anyone have a engine? is there anything I should know? Are some ears bad, some good? DO I need front or rear sump or my mkiii?
Thanks!
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
those "Supra" automatic 1JZs are more often than not Chaser or MKII 1JZ's which require way too much work to really make them cost effective.
Call Jhot Imports in denton, tx or Georgia for a JZA70 set
they are a little over $1700 from them and they come with everything you need for the swap and they stand behind the parts (buddy of mine works there, so im very familiar with the company)
92TealSupra
Sep 2, 2008
1,584
Great Lakes State
oh thank you. That helps a lot adn yes They are out of cahsers is there a different like engien brackets and oil pans?
Bigzavs
Apr 21, 2005
2,267
Arlington, TX
yup, oil pan and mounts need to be changed, harness and ecu are wrong (possible to get them to work tho) youd need JZA70 TT piping if you went with the stock twins (chaser discharge points out at the fender) and theres probably some other things
my motor is a chaser, if i had it over again, id have just gone with the jza70 set for more money. after getting the pan, bellhousing, flywheel, right harness and ecu or getting them to work you've spent way more than the real supra set would have cost you
92TealSupra
Sep 2, 2008
1,584
Great Lakes State
your buddy company has a website are they on Ebay or?
Bigzavs
Apr 21, 2005
2,267
Arlington, TX
yup, rear sump for our cars
if theyre listing 100,000 its most likely kilometers, which would be 62,000 miles
92TealSupra
Sep 2, 2008
1,584
Great Lakes State
kwnate;1146821 said:
I did already Nate. I searched, but there was no real sites I could look at I found that Aaron could help, but I wanted a couple more sources, and also what I should expect to pay. :) Don't worry I use that search button
