Where to find cheap 550cc Injectors
JohnRardin
JDM 7MGTE
Apr 4, 2006
110
Radford, VA
I just did a JDM engine and transmission swap and it looks like my fuel injectors need to be replaced. Where can I get the cheapest 550cc low impedance fuel injectors? I can get a 20% discount from Advance Auto Parts, so I'm hoping to find something that I can get there. Anyone know where to find cheap rx7 injectors? Are the 2JZ-GTE injectors any better or worse than the '87 rx7 injectors?
RacerXJ220
Interdimensional
Abalama
Search man.
Ebay, SF, here in the for sale sections.
The 2JZGTE injectors are different.
You can use 87 rx7 injectors. Even a couple of domestic injectors will work, high or low imp, you just have to change a few things. Discussed many times already.
C
cnewingham
Guest
Arpus here on the board has some rx-7 inj. and they are under $300 cleaned and flow tested.
Justin
Speakers?
Spokane, Wa
Honestly man, I'd be really warry of putting cheap and injectors in the same sentance.
I've never bought a set of used injectors without getting them flow tested prior to use...
If you get a shitty injector or clogged, or anything... boom goes the entire engine. Definatly a part you wanna wait until you can afford the right thing, ya know?
jdub
Feb 10, 2006
10,730
Valley of the Sun
Well said ;)
JohnRardin
JDM 7MGTE
Apr 4, 2006
110
Radford, VA
I wasn't really planning on getting used injectors, and if I did it be stupid not to have them flow tested and/or cleaned. The main thing I wanna know is where to find the best price on new ones.
chriso
Supranian
Bay Area, CA
I've got a set of Lucas 550's for $300 shipped. No connectors though. They are identical to the RC Engineering ones. They are immaculate also. They have literally 10 miles on them.
