Installed my OBX boost guage, well I ran the wiring but I do not know where i should drill the hole for the vac hose to run through to go to the engine bay? any suggestions?
try and find a hole that has been pre drilled either from factory, or maby for an aftermarker allarm. thats how i ran mine, just pulled the other wires out of the way enough to run the vac line through. :icon_bigg
right by the clutch pedel is a empty hole, if you look in the engen bay to the lower left of the clutch master cylender their is a pyle of sylacone, and a small hole in the midl of it, that goes all the way into the cab right by the clutch pedle
