Where to buy lash caps?
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
hey guys, im having some cams reground with a smaller base circle through a company we deal with at my work, i just need to know who makes lash caps for the JZ motors? if its one of the major companies i can get a hell of a deal on it.
Most companies ive looked at have different valve widths listed, what is the size of the jz if anyone knows?
thanks guys
tissimo
Stock is boring :(
Melbourne, FL
lash as in the shims? toyota has them. A machine shop might have them. They're pretty common on all newer toyotas.
Bigzavs
Apr 21, 2005
2,267
Arlington, TX
IJ.;955685 said:
lash caps usually go under the stock buckets to take up the clearence left by smaller base circle cams so you get back into the stock shim adjustment range.
bingo, i just have no idea what size id need to get.
sizes ive found are
5/16
11/32
3/8
6mm (crower's site has this listed as toyota set of 24, so maybe?)
8mm
You need to measure the pocket in the top of the retainer to get caps the right diameter that will locate correctly.
Then you need to know how much is missing from the base circle so you can get the right thickness.
Bigzavs
Apr 21, 2005
2,267
Arlington, TX
Ric;956086 said:
Yamaha R1 lash caps are cheaper then toyota units
i think your thinking of the buckets/shims
so far ive found crower, manley, comp, or crane
im gonna call crower from work today (business accounts rule btw)
Bigzavs
Apr 21, 2005
2,267
Arlington, TX
once the cams are in, and i have them shimmed right, im gonna go to shimless buckets, but thats not for a while
so yamaha shims are cheaper than getting them from toyota?
