Where to buy copper fuel washes?
D
drumminforev
Guest
Ive been to ace, homedepot, bap, autozone...none have
The dealership is closed today, so where else could i get a set of copper washers for the fuel rail feed bolt.
johnathan1
Supra =
Aug 19, 2005
5,056
I got mine at a store called "Autoaid"...they just brought out a huge container with a bunch of washers in it, and let me pick out the ones I needed...I would think AutoZone should have them.
I have also been told that you can reuse the old ones if you heat them up with a torch before putting them on? Not sure how well that actually works, though.
D
drumminforev
Guest
We done have an autoaid out here. And i would have reused them in a heartbeat but i lost both of them
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
I found all but two at AutoZone. The store I went to had them in a ton of different sizes, they were all behind the counter.
Annealing the old ones softens them up. It's not going to fix them if there's a gouge in them, but the surface is smooth it could work out alright. I'd rather use new ones and not worry about it... it's not a bad idea if you're in a pinch though.
ma71supraturbo
Redding, CA
www.geocities.com
Never reuse fuel o-rings or copper washers. Sure it will often work, but do you really want to take the chance with 40psi of fuel behind it? A burnt engine bay is much more expensive and time consuming to fix than getting the parts to do it right.
supra90turbo
shaeff is FTMFW!
32
MA, 01440
I agree wholeheartedly with Jeff.
New copper washers are cheap. Spare yourself an expensive mistake and buy a few new washers before you put it together.
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Not that I'm an advocate of it but people have been re-annealing copper washers in aviation for decades. They're what seal spark plugs on piston airplanes. A whole lot more pressure than fuel and it works fine. I also have a Bosch K Jet equipped engine that uses the things all over the place and often re-use them after a bit of heat without problems. K Jets run at 80 psi.
Not that you should do it unless you have too. Fwiw you can buy a complete assortment of the things for not much money from most industrial supply places. MacMaster-Carr for example. That way you'll have them around when you need 'em. Same with O rings, ect. Beats buying stuff one at a time. Not to mention the hassle saved.
8,897
What does heating the washer do to it?
The rule is that after it has been crushed once, get a new one. Which is why they are included in the kits.
