I thought I found the B ground wire. Is it on the harness right next to the fuel injector plugs? Thing is, I grounded it to the intake mani, and now I'm not getting power to the ECU at all. Undid the ground and still no power. Strange. For the hell of it I tested the EFI 15A fuse in the engine bay. With the battery disconnected, voltmeter shows 12v when I connect the leads from the battery positive to the top of the EFI fuse. However, when I reconnect the battery to the fusebox and perform the same test, I don't get a reading. Does this mean I'm shorting out somewhere? Is there a breaker or something perhaps?
The battery is an Optima Blue top and it has never been charged since I purchased it 8 months ago. The Supra's lights still power on and aren't very dim, so there should be plenty of juice left. The voltage has been gradually dropping over the last few days. Yet it's still above 12v.
This seems like such an easy issue; I'm starting to get pissed at myself for having such a hard time with this
I haven't messed with an electrical system in a very long time.
