where does this plug go
Status
Not open for further replies.
themadhatter
760
Vegas
on my 87t there is a green square plug i can't figure out what it goes to i beleave i circled the same plug in the piture because they are in almost the same location but the one in the pic is gray (year difference?) can any one help
themadhatter
760
Vegas
that would make so much sense thanks guys
and bye the way should the injectors go from closest to the firewall moving forward red white or white red?
ross1
188
va
i'm pretty sure that doesn't matter as long as it's opposite colors each injector, and you don't stretch the wires too much
ross
stratoayu
435
surrey
ross
how woul dit not matter... the ecu needs know to send a signal to that specific injector to tell it to squeeze... without gas.. no boom. no boom, no power. but hey, thats just waht im thinking :)
NickSupra
179
tn
Definitely dont swap the injector clips around. They should be in clusters of two coming out of the harness. 12 34 56 for example. From there you will have to find some way to determine which is which. I cant tell you exactly.
suprarich
Guest
Nov 9, 2005
2,187
ohio
NO NO NO, it goes 1&4, 2&5, 3&6 on the injector batch fire. The wire colors would be
1&4 Yellow/ white with blue stripe
2&5 Black/ White with Red stripe
3&6 White/Red
ignor the color of the plastic cap
themadhatter
760
Vegas
all the injector clips on my harness are 3red or 3white no yellow or black unless your talking about the color of the wires maybe?
suprarich
Guest
Nov 9, 2005
2,187
ohio
empera said:
does the actual wiring of the injectors matter? like which color goes to the harness.
Yes it does, our injector system is call Bank fire or Batch fire, like I said in my post above, 1 and 4 are the same, 2 and 5 are the same, and 3 and 6 are the same. colors I stated are for the WIRES, not plastic clip color. Always ignor the cap s Go by wire color.
Status
