Devin LeBlanc;1641088 said:The two near the alternator go to the ignitor which looks like you are missing..
The 4 pin white connector looks to be off of one of the tems actuators on the shocks
The green with red stripe goes to coolant temp sensor on thermostat housing (There are two the other one that is a single wire is for the gauge cluster temp gauge
The Blue with white stripe goes to the auxiliary fan sensor on the thermostat housing for the big fan in front of the condenser
Hope this helps
Thanks
vIetDrIfTeR;1678480 said:k more question of where shiet goes
yeah this a positive wire i do not see where it goes n do not see where its suppose to go??
and what plug, plugs into this
i dont see any wire that goes to this?? this car is missing a bunch crap sorry
thanks
TweeT91109;1678513 said:
This is a plug for a vacuum line. If its not plugged in it will just throw a code. The vacuum lines should be hooked up though if your running all the stock lines. One goes on the manifold I think, the other is for the fuel rail.
Possibly goes to the starter. But idk where its coming from.
Devin LeBlanc;1678531 said:Solid black goes to the block.. Main engine ground
