where do these go?
mustangmatt98
georgia
Title says it all:
I know the top line is for power steering valve but I can't figure out how its supposed to get there from the other side of the motor. The bottom one I'm pretty sure it goes into the back of the water outlet then gets a rubber line to the turbo....just wanted to make sure.
Also on the bottom of the lower intake near the front there's a nipple coming out the intake. What needs to run to it? On the upper intake on the back there are 2 vacuum ports. What runs to those?
supraguy@aol
Well-Known Member
Dec 30, 2005
4,236
Atlanta
Yup. And that vac nipple you see at the front of the intake is what connects to one end of that hard line in your pic.
The other end goes into the idle-up valve on top of your PS pump.
