Where do these go?
garyb
47
Michigan
I am thinking that I may need to pull the plenum to figure out some of these but thought I might get help here also. One of my arms is in a sling from an op this am and Doc says take it real easy on it so will try these pics. 88 turbo "basket case" I am figuring out the puzzle! Can't find where the hose goes? About the size of a fuel hose but don't think it is the return as I have that one hooked up to the fuel rail already. Any ideas? Also, the two loose wires with large terminal lugs? And the white connector at lower right of pic? Thanks
isnms
United States of America
Oklahoma
i80.photobucket.com
• the large hose appears to be a coolant hose
• the small hose may be your bov vacuum
• the wires are grounds that attach to a bolt on the intake plenum
garyb
47
Michigan
Looks like one more piece of the puzzle is solved-the wires with terminals for ecu grounding. Thanks. Still wondering about the white connector in first pic (left one) at the lower right corner of the pic. Also, I don't know why there would be a coolant hose on the driver's side as the coolant stuff seems to be on the passenger side. Is there some kind of sensor it could go to?
garyb
47
Michigan
I plan to connect it (the coolant hose) but can't see the fitting at the block. Is it underneath the intake on the block? If so, about where on the block?
jetjock said:
Can't help with the connector but the bigger hose looks to be part of the ISCV and TB coolant loop. Many people disconnected them but I use it for coolant bypass filtration.
