It's a step down because MAP based systems are not as exact as MAF based ones. Speed-density takes the MAP and IAT readings, then applies them in a mathematical equation and comes up with the fueling it thinks the engine should have. MAF just looks how much air mass is moving into the engine, which is more accurate.
I like MAP due to the simplicity, but there is nothing wrong with ther MAF system. Well, not unless you're a ricer and wanna hear that awe-inspiring whooopssssshhh
Edit: People usually go MAP based when they go to a standalone computer (AEM, MoTeC, etc) or an advanced piggyback (maft-pro, MAP ECU, etc). It's all about control- how much can you change fueling and timing on the stock ecu, vs how much can you change with a fully adjustable ECU?
