where can I get
Enraged
A HG job took HOW long??
24
Victoria, BC, Canada
make them yourself... HPF sells the EGR plates for $45... for that much, you can buy aluminum plate/stock and make them. all you really need is a drill, a hacksaw, and a file. also, i havent seen the CSI or IAC blockoff plates, just the EGR and J-tube.
gixxer750
2jzget comingsoon!
Mississippi
well, I have made all the others before....but I really want a polished IAC block off, as it will match my newly polished manifold....
Disco Stu
Unaturally Aspirated
Apr 6, 2005
51
Forth Worth
weld a plate on and polish it out! ;) I have never seen any premade plates for anything but the EGR and J-tube. A bench grinder would be very usefull in this situation...
mkIIIman089
Ohio
Unfortunately I am not sure what an IAC is. But John Lunsford (JBLMK3) makes all the others which are very high quality and relatively inexpensive. Only EGR are listed on his site but IIRC he said he can get CSI ones makes as well. You will have to get new gaskets seperate though.
Disco Stu
Apr 6, 2005
51
Forth Worth
I think he may mean the ISC valve, next to the TPS, but I am not positive. I didn't know John could do the CSI too, that's cool, if you need it.
