Are all 89+ turbo models ECU pinout diagrams created equal? I have a 1991 Supra turbo.
I have this MAP ECU that is not getting an RPM signal. Until it does it will not tell the stock ECU what to do with the injectors. So my car ran as if it didn't have the AFM plugged in. I had to reinstall my AFM to get my car to run right. I have no CEL codes.
Where can I directly tap into to get an RPM signal? Does it come off the ignitor? I have my MAP ECU tapped into the IGT pin on the harness and it's not picking up the signal. I was going to try IGF, but that's just the return signal from what I understand. Is there another source?
BTW, all piggybacks need an RPM signal. This isn't a MAP ECU specific question. So if you have some other kind of piggyback please chime in where you found an RPM signal.
