My brother wants to know if he needs bigger injectors for his 1jz if he put in 264/272 cams? If you need to know the other mods he has, 3'' dp, exhaust, 2.5 int. piping, 24x12x3, intake.
rakkasan said:Never mind, I don't give a shit. Roll the dice if you wish.....
tsuper92 said:my 1jz ran fat down low and lean up top with cam's.also had 550 injector's and small single
high psi 1jz said:Ok you didn't answer my QUESTION: Do I need to upgrade my fuel (injectors) for 264/272 cams? You and people tried to tell me what I'll need for full fuel upgrade, all I wanted to know was injector size. I know the supporting mods I will need and I don't want all these newbie questions which I have answers to.
high psi 1jz said:I'd like to hear a reponse from someone with the cams, I don't want the "I think, I would" replies, not to down your inteliigence and that will be upgraded eventually but my original question has not been answered unless csnow: you have put cams on your 1jz?
annoyingrob said:I ran stock injectors on stock twins with crower small core 272 cams. Worked fine. The duty cycle got into the 90s when you pushed up to 7500rpm, but it still flowed.
