Ok guys just wondering would it be dumb to put spacers on the mk3 with the mk4 TT wheels? and have any of u guys used spacers before if so how is it?
supraman7mgte;1641401 said:get whatever makes your wheels stick out to your desired taste,but don't go too wide risking style for safety.
A. Jay;1585781 said:(...)
Since the stock mkiii wheels are the same width and offset all around, I'll have to do something about the mkiv wheels so that they'll have the same distance from the outer edge to the rotor in respect to each other.
Mkiv tt wheels are 8"/9.5" wide front/rear, +50 offset all around. That means the rear wheels will "stick out" more than the fronts, and my solution will be to get a spacer for the fronts. I made the calculations, and it looks like the rears stick out 19.05mm more than the fronts, so I'll need 20mm spacers. The results will be like .7" farther out than stock all around. My goal is to only have to buy one pair of spacers while still having the wheels stick out more, which seems like it's possible(...)
A. Jay;1641431 said:Yea, all we can do is give you opinions, so here's mine (from http://www.supramania.com/forums/showthread.php?125470-MKIV-TT-wheels-questions):
