wheel hub studs
jimi87-t
1,127
5
Colorado Springs
I'm needing to replace my studs and want to go with ARP not OEM, So are these the right size, I don't know the proper "Knurl" size needed (part of bolt that presses into hub):
ARP Wheel Hub Studs - .485 Knurl Diameter, 2.50 Underhead Length, .275 Knurl Length, M12X1.50mm Thread
supra90turbo
shaeff is FTMFW!
32
MA, 01440
I'm just gonna be lurking on this one, Jimi. I would like to know as well about this, as I will be looking to buy longer studs when my car is nearing completion. What's the stock length?
supra90turbo
shaeff is FTMFW!
32
MA, 01440
If you don't end up getting an answer by tomorrow Jimi, I'll try to get one of mine out of a hub and mic it up for ye.
jimi87-t
1,127
5
Colorado Springs
Thanks Kurt, I went ahead and ordered the ones from HPF, I had something else I needed from them so I just went ahead and got them, we will see what happens I guess. They said they were the ones for the MKIII hubs, But I just wanted confirmation. I'll post the results under my build thread once I get them.
jimi87-t
1,127
5
Colorado Springs
NOPE!!! F'n .....They are not the right size, the "Knurl" is WAY too small on these. The ARPs that Horsepower Freaks lists under MKIIIs is not the correct ones. The package says they are for Hondas.
I guess I get to try and sell these on Ebay now, as I don't suppose I can return them. Now to try and find the right ones! I didn't want OEM, but I guess that's my only choice at this point.
supra90turbo
shaeff is FTMFW!
32
MA, 01440
If you can't return them, there is something wrong with HPF. They have them listed in error, and therefore it is no fault of yours. Now if you ordered Honda wheel studs under the assumption that they would fit, and they didn't, well... then I could see maybe, MAYBE them giving you a hard time.
Bottom line is, it's their fault, and they should honor the customer.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
make them work it's not that hard in less there to short and to skinney
jimi87-t
1,127
5
Colorado Springs
Kurt, I will see what they say, but I don't know, there was something about a 25% restock fee. They were listed under the MKIII, here is the link: STUDS
NashMan, There is no way, the part of the bolt that "presses" into the hub is too small. As in the hole in the hub is bigger than the bolt. I'm not going to "jury-rig" my hubs. :aigo:
Allan, +1 for the link, thanks.
