Wheel Bearing Packing Grease
jdc4357
56
missouri
Hi,
I am replacing my front wheel bearings on my 88 and just wanted to get an idea what everyone used. I was thinking of using Mobil 1 Synthetic Grease. Pro's.. Con's??
tia,
jamieC
jdc4357
56
missouri
I purchased brand new OEM bearings from Champion and all they have is a slight oil to keep from rusting I assume.
Thanks for everyones input.
jamieC
supra90turbo
shaeff is FTMFW!
32
MA, 01440
Just because they come with grease doesn't mean it's the best, or even close.
Since when do we just leave things alone, anyway?!
Koenigturbo
1,337
Oxnard CA
I thought the fronts are sealed bearing
shaeff
Kurt is FTMFW x2!!!!
10
Around
Exactly. OEM's tend to try to keep cost down. Redline CV2 is expensive stuff (nearly $60 for four tubes), and not likely in the budget for packing OEM bearings. ;) I'm rebuilding the M3's CV axles with CV2 as well. ;)
