Ok, so after diligently tried figuring out why my car was only boosting around 5PSI, I think I may have found the problem. From checking all vacuum lines to making sure everything is in top shape. I decided to try shimming the wastegate and see where that gets me. So I added 2 washers to both sides, turned on the car...thought I broke something for a second until I realized that I didn't connect the AFM :nono: So I connected it up, turned on the car and took it for a quick drive around the block. At first I could have sworn I smelled something burning, but I drove around quickly anyways. So I pulled it and still, no increase over 5PSI, and if anything it barely raised above it. After stopping back in front of my house I really couldn't help but notice the smoke coming out from under my hood. :aigo: So I popped the hood and found smoke coming from the exhaust manifold/turbo side. A friend of mine, Johnathan, was saying that it's possible when the gasket was replaced for the manifold that the shop that did it may have covered up the little oil feeder hole with silicon if they did do that. Aside from that, is everything here pointing to a blown turbo?
