Today driving around, moderate speeds, kinda slow...my oil pressure was at the lowest mark that's in the "normal" range as per the owners manual but i dont like how low that is compared to some other instances where its been higher.
i'm running 5w-30... i think this weekend i'll change my oil to the good castrol i bought, and put on a better WIX filter.....but i still would like to know if this is normal. i checked the level and its still about a quart over since i filled it with fresh after the BHG fix assembly.
on cold mornings my gauge shoots up to almost 80.... backs off by the time she's warm...
and then when its warm/hot its stays around the 2nd lowest line without a number by it, its the line just above the one that would mean no oil pressure. i dont run it hard because i'm not running name-brand oil and i have to change my oil...so i dont know how she reacts to hard running nor did i want to try - before i fix some issues... i'm a worry wart and the owners manual says its fine but considering how toyotas messed up some things i had to check.
and i was worried about a clog...but now that i think of it... maybe low pressure is good because pressure is resistance to flow...just as long as i have oil.
so i gave up thinking and guessing (because i dont really know whats best) and thought i'd ask what you guys commonly get when driving easy. i revved my engine and it pushed the needle up a little but it just didnt seem to do much today.
