whats up with the locks?
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
so the weather is getting colder, and aside from the gas shocks not holding up the rear hatch anymore, not too much is going wrong (knock on wood).
except for the door locks. i have to manually lock the doors because it seems like the 'noids or whatever operates the lock isnt getting enough power. when i lock it, the locks will click over about halfway (not enough to lock) and i have to push them the rest of the way.
any ideas?
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
Dude, atleast yurs kinda work, lol, mine are worthless... One of the previous owners put an aftermarket alarm, and my power door locks are f'd up... And I have to unlock my passenger door before i unlock my driver's door or else the alarm will go off and/or the starter kill goes into affect...
I havent spent much time chasing it down, but I will one day...
PIONEER
Wallet Wide Open
Raleigh, Nc
The switch on your driver's side door lock barrel is probubly broken or dirty. Thats what triggers the Arm/Disarm of the alarm when you turn the key. Take the thing out, spray some WD40 or some parts cleaner and clean it good and put it back on. The Lock should start working again.
SupraMario
I think it was the google
The Farm
LOL, I think a lot of us have annoying problems when it comes winter. least we got damn good heaters, :)
when i lock mine by key they go half way. then slowly click over after like 30secs.
mrnickleye
Love My Daily Driver !
Jun 8, 2005
825
Mojave Desert, Ca
Clean and lubricate! Clean & Lubricate! Kleen & Lube !!
Clean and lubricate! Clean & Lubricate! Kleen & Lube !!Clean and lubricate! Clean & Lubricate! Kleen & Lube !!Clean and lubricate! Clean & Lubricate! Kleen & Lube !!Clean and lubricate! Clean & Lubricate! Kleen & Lube !!Clean and lubricate! Clean & Lubricate! Kleen & Lube !!Clean and lubricate! Clean & Lubricate! Kleen & Lube !!Clean and lubricate! Clean & Lubricate! Kleen & Lube !!Clean and lubricate! Clean & Lubricate! Kleen & Lube !!Clean and lubricate! Clean & Lubricate! Kleen & Lube !!Clean and lubricate! Clean & Lubricate! Kleen & Lube !!Clean and lubricate! Clean & Lubricate! Kleen & Lube !!Clean and lubricate! Clean & Lubricate! Kleen & Lube !!Clean and lubricate! Clean & Lubricate! Kleen & Lube !!Clean and lubricate! Clean & Lubricate! Kleen & Lube !!Clean and lubricate! Clean & Lubricate! Kleen & Lube !!Clean and lubricate! Clean & Lubricate! Kleen & Lube !!Clean and lubricate! Clean & Lubricate! Kleen & Lube !!Clean and lubricate! Clean & Lubricate! Kleen & Lube !!Clean and lubricate! Clean & Lubricate! Kleen & Lube !!Clean and lubricate! Clean & Lubricate! Kleen & Lube !!Clean and lubricate! Clean & Lubricate! Kleen & Lube !!Clean and lubricate! Clean & Lubricate! Kleen & Lube !!Clean and lubricate! Clean & Lubricate! Kleen & Lube !!Clean and lubricate! Clean & Lubricate! Kleen & Lube !!
turbo
Mr. Clean
Apr 27, 2005
135
Calgary
I agree with the clean and lube. Just stick some lock lube in all the locks every month or so and you will have no problems. Forever.
Clip
Oct 16, 2005
2,738
9
Virginia
so cleaning and lubing the locks should make em smooth enough to click over in colder weather?
haha, that heater is always kicking...gets hot after about 3 mins of driving and feels damn good in the winter
S
supra_G
Guest
also i noticed when my battery gets low the locks only click over half way!!!!
mrnickleye
Jun 8, 2005
825
Mojave Desert, Ca
Well thats because the locks need cleaning and lube, so there is a lot of resistance. While your in there, you should clean the connectors and the grounds, for better current flow.:icon_mad: :icon_razz
