What's this J-Tube mod?
Doward
4,245
Alachua, FL
I'm thinking of getting a MkIV fuel pump to replace my old one... I'm hearing things about a J-Tube mod, and a search yielded very little.
SupraForums.com is down. Big suprise. :3d_frown:
Can anyone point me to a link, or detail what and why the J-Tube mod is done?
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
Heh... this is pretty simple.
The Engineers at Toyota wanted to make sure you could have enough fuel pressure to make it to a shop even if your pressure reg failed. So, they put a restriction in the return line - it's called the J-tube, and it's a J shaped tube bolted to the intake side of the block next to the motor mount.
When we go for more fuel delivery, this restriction can cause problems - so people bypass it or drill it out. Just make sure you have a good pump and fuel pressure regulator first. :)
lagged
1991 1JZ
new rochelle
the jtube is a fail safe incase the stock FPR blows up. when you install an AFPR along with a high flow fuel pump such as a 255lph unit you bypass the jtube. sefl explanitory.
you can then either leave it there, by a block off plate, or remove yours and grind down the tube, polish up whats left over and have a jtube "block off plate" for free :)
edit: grimjack beat me to it!
shaeff
Kurt is FTMFW x2!!!!
11
Around
boost fiend said:
so what fittings need to be blocked off?
none, it's either bypassed completely, or you simply drill out the end of it. here's a pic of the part that needs to be drilled, if you decide to actually drill it. see that little pinhole in the end of it? yep, drill that out! :)
the other option is to get some regular gas line and just compeletly bypass it, going from the fuel pressure regulator's return side, directly to the return line under the car. :)
on to the pic:
-shaeff
shaeff
11
Around
supra90turbo said:
shaeff, the resident J-Tube expert, so it seems. lol
Nice pic btw. :bigthumb:
haha. that's one of the most commonly asked questions, so if there's a plethora of information about it, surely when the next person uses the search function, it'll pop up, thus saving us from reposts in the future. :)
aside from that, i'm starting to work on som FAQ's, of which include the J-tube mod. :)
-shaeff
