What's the ideal engine temp to be at??
c_ronius
1jz 4Runner
Jan 2, 2007
109
Tampa, FL
www.rsworld.com
I'm wondering if I should raise the temp on my 1J.
The stock t-stat opens at about 180 F, I have a controller for my electric fans,and I set them up to cool at 185. When running it stays dead on 185 all the time.
Will there be a performance or fuel economy difference if I raise the temp? What is the IDEAL range for a 1J?
I set it close to the t-stat opening temp because I didn't want it to drop too much if I were driving on the Interstate with all the wind cooling it down. I figure a constant temp regardless of driving conditions is the way to go...like factory cars, right?
Now that I've driven the beast for a couple of months the temp never moves from 185, even on the interstate. I think I can turn it up without it fluctuating, so I was wondering if I should do so....
Thanks.
Nick.
jdub
Feb 10, 2006
10,730
Valley of the Sun
Most Toyota ECU's are happy with a coolant temp between ~180 to 210 deg F. Based on what you said, yours looks good ;)
tissimo
Stock is boring :(
Melbourne, FL
the tstat is 180? the 2jz one too? I thought it was 190.. I set my e fans to come on at 195.. if its 180 I can drop it
str8_6
master yuepeng
Mar 14, 2007
241
wa
man i think my sensor is off or something then...i have a megan racing gauge and on my 1j it never goes over 175degree unless i let it idle for more then 10minutes after driving a long time, while driving on freeway the temp is around 145degrees and most importantly i dont even have my e-fan setup yet.
fstlane88
Single time!!
South FL
This is an interesting thread, I was thinking my car was running hot (200-210*F range) due to it only having one fan on it, but sometime it doesn't even get up to that so it's no even getting up to normal temp. Well I've already ordered some Spal fans so we'll see what they do.
drewgo
Akuna MaTata...!
Dec 1, 2006
482
South florida
I am stuck... on the SC there is no #'s just little lines. Mine stays dead center, if anyone know please let me know on the SC if that is 180.
Ric
Setting the standard
Feb 22, 2007
1,432
Central Florida
www.1jzgte.us
Stock twin 1JZGTE's run hot by nature. If you're under 210 degrees that's a miracle upon itself.
Since I've gone single.. I don't even need to turn on my radiator fan. I've sat in traffic in 90 degree air temp with it off for 5 mins and the water temp is still under 200. Using just a factory 3 row MKIV TT rad and 190 degree stat (ive always got the best fuel miledge with a 190).
