whats the difference between a N/A head and a turbo head?
laxboy36 Member Mar 25, 2010 282 0 16 Chesapeake, Virginia Dec 9, 2010 #1 whats the difference between a N/A head and a turbo head?
te72 Classifieds Moderator Staff member Mar 26, 2006 6,610 7 38 41 WHYoming Dec 9, 2010 #2 The head castings themselves are the same. Only difference is the things inside the head, the cams.
laxboy36 Member Mar 25, 2010 282 0 16 Chesapeake, Virginia Dec 9, 2010 #3 so if i buy a n/a head and put turbo cams and comp springs in it i should be fine
SURUKO making the supra better.. Jan 8, 2007 610 0 0 The tropical island.... Dec 9, 2010 #4 laxboy36;1648031 said: so if i buy a n/a head and put turbo cams and comp springs in it i should be fine Click to expand... Yes...
laxboy36 Member Mar 25, 2010 282 0 16 Chesapeake, Virginia Dec 9, 2010 #5 whats the best idea to do if i get comp springs and have the N/a head?
RazoE Boobs/Boost, my favorite Jun 13, 2006 4,946 3 38 39 Los Angeles www.cafepress.com Dec 9, 2010 #6 only 1 cam is different, and it's not really that much of a difference..
Jeff Lange Administrator Staff member Mar 29, 2005 4,919 5 38 38 Sunnyvale, CA jefflange.ca Dec 9, 2010 #8 Don't worry about finding turbo cams, the N/A ones are very similar. Jeff
bioskyline New Member Oct 21, 2010 1,236 0 0 powell river bc Dec 9, 2010 #9 the exaust cams are they same, the intake are different, but the n/a cam has a slightly longer lift, so wont harm anything
laxboy36 Member Mar 25, 2010 282 0 16 Chesapeake, Virginia Dec 10, 2010 #10 well i have a 88 turbo and t has 105K stock engine. But i found a head and cams for 130$ and i want to put comp cams in it, and clean the head up
Jeff Lange Administrator Staff member Mar 29, 2005 4,919 5 38 38 Sunnyvale, CA jefflange.ca Dec 10, 2010 #11 Sounds good then. Jeff
