what's in the toyota valve grind kit?
Oct 11, 2005
3,816
Thousand Oaks, CA
I am trying to find out what's included in the Toyota Valve grind kit p/n 04112-42023.
Based upon the parts catalog illustration I came up with the following list. Can anyone confirm?
valve grind gasket kit contents
1 90301-07001 6 fuel injector o-ring
2 90430-14007 1 Gasket, Pipe Fuel Delivery Inlet
3 90430-17006 1 Gasket (For Pulsation Damper Hose)
4 90430-10204 2 Gasket (For Fuel Pressure Regulator)
5 23293-42010 1 Gasket, Cold Start Injector
6 90430-08012 2 Gasket, Cold Start Injector hose at injector
7 90430-12026 2 Gasket, Cold Start Injector hose at fuel rail
8 90430-12026 2 Gasket (For Fuel Pipe Support)
9 11213-42020 2 Gasket cam cover
10 90430-37140 1 Gasket oil filler cap
11 90311-35017 2 camshaft oil seal
12 90913-02062 12 intake valve seal
13 90913-02062 12 exhaust valve seal
14 11115-42021 1 head gasket
15 17173-42010 1 exhaust manifold gasket
16 17278-42010 1 turbo to exhaust manifold gasket
17 17177-42020 1 intake manifold gasket #1
18 17176-42020 1 intake manifold gasket #2 (surge tank)
19 16341-35010 1 thermostat gasket
20 90917-06050 1 turbo elbow to downpipe gasket
21 90430-22008 2 Gasket (For Water By-Pass Pipe)
22 16343-42020 1 water outlet housing to block gasket
cjsupra90
previously chris90na-t
Jun 11, 2005
1,029
Lakeland, FL
didn't notice anything missing there from what you posted.....
Pretty much everything needed to basically rebuild the head outside of the physical valve train hard parts (I.E. valves, valve seats, valve springs, ect...) as chances are that you wont need those items.
Oct 11, 2005
3,816
Thousand Oaks, CA
Thanks!
The things that seem to be missing to me are the turbo water/oil line gaskets, the water bypass pipe to thermostat housing gasket, and the EGR gaskets. Plus some of the gaskets on the intake for ISC, throttle body, and so on. I was going to order those if they are not included, but I'd rather not wait until the kit comes in to find out what the missing pieces are.
cjsupra90
Jun 11, 2005
1,029
Lakeland, FL
the crush washers and gasket for the oil feed and drain at the block were in mine the last time that I bought one, but that was like 2 1/2 to 3 years ago.
You dont remove any of the hardware from the turbo itself. Coolent pipe and oil pipe assemblies stay attached to the turbo so no need for the gaskets at the turbo
