what turbo setup u run
935motorsports
San Diego, CA
I'll post for Jason and Lenny
There are several setups in the stable right now, but these 2 are on the road:
GT35, t3 housing, china manifold, 366rwhp @ 15 psi
ITS58 ball bearing, t4 housing, china manifold, similar power, but have not seen the dyno yet. Will post an update soon.
I
itr206
Guest
T4 GT40
Stryder Manifold with Tial 44MM
508whp and 501 tq with an SAFC tune on the stock ECU. I also found out I had problems with a boost leak.
So there will be more to come shortly.
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
MDCmotorsports said:
I run the hks Ta51 (t66) turbo with a ebay manifold and 40mm wastegate.
I turned out 315 hp (365 on a dynojet) @ 10psi on stock manifold.
John, I think he asking people with 1j's...if you did a 1j swap that I didn't know about...you better fess UP!!!
7Mboost
7M Powered
Aug 15, 2006
2,201
Gainesville, FL
itr206 said:
T4 GT40
What rpm you making boost at?
I
itr206
Guest
What RPM do I make boost at? I see positive bost about 3k or so. I see full boost about 4K
Slow_Sc3
I beat bikes dude
Apr 2, 2005
401
Maryland
havnt tuned it yet but right now its just 550cc injectors, and a safc-2, t78. dyno day is in 3 weeks then everything will be worked out. i will be running wastegate springe for awile ;).
mk111ricky
29
orlando fl
hey after u get it on the dyno u mind leting us know how u did. I was planning to go with the T78
Slow_Sc3
I beat bikes dude
Apr 2, 2005
401
Maryland
ya it will be a little bit but ill post up my dyno when its done.
Slow_Sc3
I beat bikes dude
Apr 2, 2005
401
Maryland
