ordered a 3" down pipe from suprasport.com, iv been waiting for it for a while now. i ordered it on sept. 9th and still dont have it. i cant get anyone to return my emails or phone calls. what should i do???
i also ordered a full 3" exhaust off driftmotion.com
next on my list to do is suspension
im looking for 2"- 2.25" lowering springs, but so far have come up with nothing... if anyone knows if a site that has 2"- 2.25" lowering springs could you let me know please...
if i find some they will be paired up with a set of bilstein struts. some better sway bars and strut tower supports (i have one out of two)
after suspension ill be looking to change the stock intake manifold and IC/ IC piping over to the 1jz FFIM that i have already. the plan is to use 3" IC piping and an big IC 3" inlet/ outlet...
then on to fuel...
start with some 720cc injectors, HKS fuel rail, FPR, walbro fuel pump,
im really leaning on the holset turbo, but not 100% on what one to use. i was thinking the HX55. but i dont know it its too much for the 720cc injectors or not enought or what.... (any help with this)
whatever turbo i do get, will sit on a custom manifold... as i said i already have a 3"exhaust and down pipe. so i was thinking i could just custom fit the DP i have aready have to the turbo of choice.
then while im getting everything powder coated flat black im ordering pistons and rods. not sure weather to bore the block or not. kinda just want to see what a 7mgte can do on stock bore.
P&P head, +1mm valves, cams and adj. cam gears..
maybe some paint her and there,
then ill need something to tune it all up with and get he most out of everyting...
what do you guys think. what kind of numbers do you think i could get with this setup... and do you have any suggestions or tips on different things to use. something i might have forgot...
thanks
branden
