what throttle cable do i use for 1jz?
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
i don't know what throttle cable to use for the 1jz in a mkIII? which one is a direct fit or is the closes to a direct fit?
honestabe
Happy as hell :D
Jan 15, 2006
3,713
Mount Vernon, WA, USA
4 cylinder? WTF are you talking about? The JZA70 throttle cable (which is designed for a RHD 1JZ Supra) is 5 or 6 feet long. The JZA80 (MKIV) TT throttle cable is just long enough and is a perfect fit. Although you will fight with the cable when connecting it at the pedal. The 1G motor is totally different from the 1JZ and 2JZ FYI. That's the only 4 banger I can think of that you wold be refering too.
Adam
JonoTurbo
Going for broke
CT
The camry throttle cable fits like a glove, you have to swap the bracket by the pedal, and then it's a bolt in affair. I have a 6 cyl camry and the cable is the same so any cable 4 or 6 cyl from 92-96 should work.
Here's a pic of the 4cyl cable on my car:
It's pulled out but you can tuck it down beside the cam cover if you dont want it running over the top.
jza71
HELL
MN, USA
www.geocities.com
I cant believe nobody see my post in supraforums about the Camry and Corolla throtle cable. The Camry cable is about 1 inch longer than the Corolla cable. The both works much better than the mk4 ones.
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
you said the corolla throttle cable also works and its an inch shorter? so it should fit better right? is it still like the camary, pretty much a direct fit? what year corollas?
OneJoeZee
Retired Post Whore
aboard the Argama
Adam
honestabe said:
What 4 banger Camry cable? Did it come off of the twin turbo Camry?
Adam
1Gs are not 4 cylinder engines, so slow your roll with the "wtf are you talking about" attitude.
and if you know anyone with a twin turbo camry, I'd love to see it. Sounds cool.
