what temp do you tune your EGT to
S
Slow Poopra 7MGTE
Guest
just wondering what not to go above as far as egt's for the supra and what not to go under for running pig rich, like a nice little ball park... anyone? and if u could explain why. my mods are in the sig if u wanna know what i am running and tuning
mkIIIman089
Ohio
IIRC EGTs go up if you are rich or lean and cool down at a good combination. I'm not 100% on that but thats what I remember reading for some reason.
However, do you not trust your wideband? I would tune with that pretty much solely since tuning EGRs is kind of like an oldschool replacement for the then rediculously expensive WB kits.
S
Slow Poopra 7MGTE
Guest
need money so i was thinkign about trading my friend for his egt set up, and 100 bucks.
by the way someone has to know something
lagged
1991 1JZ
new rochelle
yeah i know something, you dont tune by EGT.
that said, i was running around 1550max which SHOULD have been safe, but my failing fuel pump still caused me to detonate and blow a HG.
EGTs should be used as a WARNING that you are at the meltdown level, you dont tune by it.
S
Slow Poopra 7MGTE
Guest
plenty of people tune by egt, and thank you bic for answering the question
antman
632
TN
they won't be ballin for long. sorry man.. there is no way to tune on egt alone. its not possible to determine exact fuel ratio by egt.
Charlie97L
230
Clarksburg, MD
EGTs are such a PITA to install... you have to take the turbo off, and the manifold off, and tap it, and everthing. blah. just get a wideband, save the egt for your rebuild.
dav_dman
old guy
Oct 23, 2005
107
louisville KY/so.IN metro area
still new to 4 strokes, but I"ll be tuning my supra same as i do those.. a/f first, timing or boost changes raising temps until i max out at 1400F... 1450 max on 93 octane as far as i am concerned. I dont see you needing it unless you're gonna go big hp, like 500 and up. Had egt's on the 2 strokes and will not bother on the supra, but i won't be going more than 14psi boost either.
williamb82
909
4
Tampa, Fl.
i have my egt probe right on the #6 runner and never seen it go higher then just over 1500deg f. if it ever hits 1600(which is the max on the gauge btw) ill shut down imediatly. i really only look at it if making long pulls anyhow like on the interstate or a long bridge. usually short bursts around town it reacts a lil too slow. id stick with the wideband myself if i were you.
