what size is are the stock head bolt sockets?
suprafanatic
1,607
Greenwood, IN
just wondering if anyone had an exact size for the socket on the stock head bolts?? i need to get a tourqe wrench and allen key socket to check the tourqe on them
suprahooked
Built 7M
Jun 20, 2006
1,160
pa
10mm
jdub
Feb 10, 2006
10,730
Valley of the Sun
I got a 10mm Allen wrench, cut off the angled part and used a 10mm socket for the torque wrench ;)
jdub
Feb 10, 2006
10,730
Valley of the Sun
The steel is very hard...you will need an air cut-off tool or a disk grinder. A hack saw is not going to work very well.
bowsercake
828
Irvine, Ca
10mm allen craftsmen for a 3/8s ratchet + extension will do the trick. It is a little tight in some spots but it is still fairly cheap and easy to do.h
