what size cometic to get
evildoer
Augusta, Georgia
had the head resurfaced and 3 way valve job the machinst said that he removed 18000 of a inch so what size would i need? And who is the cheapest and fastest to get a hg from thanks
empera
Authorized Vendor
Philly.
get it from 935motorsports but make sure robert has them in stock. also go with the 84mm bore one.
TONY!
Habitual Supra Killer
Tonyland
Empera has just gone through the shopping of HG's very recently & bet he did a good job shopping around & figuring out how available they are from different places.
.018" is how you state it heheh
I was wondering what in the world you were talking about.
I just made the following post but here it is as it has the same info you may need:
If you really want to know for certain what compression you will have before & after you can use this calculator http://www.angelfire.com/fl/procrastination/motor.html
You will have to find out exactly what your piston's dome dish volume would be first though.
According to my machinist, the .020" I need taken off would not really change compression but would affect timing more.
Thanks to this link http://www.worldwidemetric.com/metcal.htm, I can easily tell you that if your machinists took a total (both head & block) of .0315" off, a 2.0mm gasket would give you the same identical compression.
Anyone know what the GTE's piston dome dish volume is?
I have been wondering about that.
