what should i expect?
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
i just swapped out my stock ic for one that is longer and thicker and should flow alot better.
what should i be expecting as far as gains if any?
ross1
188
va
if your still stock piping and turbo, i'd guess you gain a little more lag for all that extra volume the stock turbo has to pressurize now. but then i'd say definately a colder air charge coming in. so once your in boost i'd say more power
ross
Bishop92t
773
USA
www.ma70.com
The stock IC is fairly adequate at low boost levels, so the gain won't be huge. I noticed a decent power increase when I went from stock to HKS IC, but I was also running 14psi at the time and had a lot of supporting mods. Really it just depends on your setup and what your current bottleneck is.
Disced
Pie + NYQuil = FTW
Edmonds, Wa
I hear a lot of "it will create more lag because of more volume."
In theory that is true; however I can tell you that from my new setup on the stock turbo FFIM/FMIC/3 INCh hard pipes/90 MM TB, again i said STOCK turbo. The car feels much quicker for the throttle response; boost hits almost 400 RPM's sooner than before, and now in hot weather the car/pipes aren't heatsoked and eating up the power; it's always there.
So take what you want from that.. But all I know is the car spools faster.. Maybe because of less pressure loss because of the 32/12/3 IC, I think i read somewhere that the stock IC has like 3 psi drop @ 10 lbs? So when you hit 10 lbs on the stock IC it's really 13.. On my IC it's like 1psi drop @ 40 psi or something.. so .25 psi per 10 psi.. MUCH more efficient.
Godspeed
88 supra turbo 5spd
May 13, 2005
1,119
Asheville n.c.
ok cool my old ic was 14 1/2x12x2 1/2 the new one is 20x8x3 and its in a better location. the car runs stock 11psi.
8,898
"More lag" is a myth. Pressure is resistance to flow. I suppose if you put huge pipes and a huge cooler on a 1.6, you could have more lag. Not in our case. I don't think you can put a big enough one behind the bumper to have that happen.
