What radiator......
Suprastic
727
Manitoba
I want to replace my radiator with either a Fluidyne or PWR, but plan on going 1JZ next winter. If i get one of these rads, will it work with the 1JZ, and if it doesn't work, is there any that will work with the 7M (specifically GE) and the 1JZ?
Suprastic
727
Manitoba
The Koyo was another I was condidering. I want to add/change a few things in my engine bay for next summer, but want to change parts that I could alos put on the 1JZ when I do the swap. Is the Koyo interchangable between the two engines.
Mob
190
Dayton, Ohio
The Koyo either is only available for the JZA70, or thats just the one Ive seen the most. Regardless, the one meant for use with a 1jz is useable with the 7m, with a few changes...at least according to the majority of people who post in radiator threads.
I could be wrong though.
Suprastic
727
Manitoba
So I guess I should just get a radiator for the 1J and don't install it until I do the swap. I don't want to have to modify it for my 7M and then have to try and make it fit for the 1J. I thought I wouldn't matter because the mounts are still the same, and I didn't think that the fluid capacity was much different between the two
