What Radiator can i use???
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
Im in the proses of sourcing parts for my 1J swap, and was wondering if there was any OEM or any other radiator from another car that would work for my swap...
I know the 7M works, but im looking to score on a junckyard radiator and the supras are always gutted out here!
Thank you!!!
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
Temp. sensor??? What... Does the 7M have that???
I suppose your right thou!!! No A70 likes to overheat!!!
The Reaper
Single, and lovin' it!!
Jan 10, 2006
1,909
Florida
only need 1JZ/Koyo radiator with the temp sensor bung if yur using the hydrofan thats all that sensor is for is the hydrofan
if yur using a 2J WP assembly and clutch fan the 7M radiator is fine
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
What are the benefits of the 2j clutch set up over the hydrofan???
JonoTurbo
Going for broke
CT
If your short on cash you can screw the 1jz temp sender into the 7m radiator drain spot. With some brackets to mount it you could run hydrofan on the 7m rad then.
87soup
F*CK SMOG CHECKS!!!
Jan 23, 2006
864
Sacramento
Really??? The thing threads right in?
That should work for me!!!!
Another Q: Is a bigger radiator better??? I think i'm stepping on to a bad subject but maybe theres a better option than the OEM's.... IDK!
The Reaper
Jan 10, 2006
1,909
Florida
really? thats interesting i'll try that....cause right now i have no sensor. the hydro fan just just runs at full blast at all times but it still works!!!!
Nopaint
110
Jan 30, 2007
172
GA
Same here...
Since we are talking bout radiators...
Another Q: Will the 7M clutch fan fit on a 2J water pump?
bobiseverywhere
bobb'n for money
Montreal
www.bobiseverywhere.com
Bigger Radiator more coolant capacity and more cooling capability. Plus the End Tanks on the KOYO are not Plastic like the OEM Stuff. People get bigger rad Generally when they have or are going to have more HP then stock. the more HP the more heat the engine produces and needs to shed off
The Reaper
Jan 10, 2006
1,909
Florida
im pretty sure it has to be a GTE
the GTE pump fits on the 1JZ so i would imagine you have to get the GTE clutch fan too
you can get the 2JZ WP assembly for 120 at toyota and then get a used clutch fan from a MKIV guy that bought efans
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
I have a quick question....I have a 1jz soarer in my car with the clutch fan. I'm about to buy a radiator for mine. I'm thinking of going with a KOYO. So my question is, I can just get a 7M radiator and I won't have a temp sensor to hook up since I have a clutch fan. Thanks.
The Reaper
Jan 10, 2006
1,909
Florida
i see no question in yur post LOLOL
if yur asking if you can get a radiator for the 7M cause you dont NEED the temp sensor than yes you are correct
AF1JZ
Jun 26, 2006
3,109
Fredericksburg, VA
Yea, I just re-read what I wrote...I'm retarded. I think I was making a statement instead of a question.
Thank you though.
Another question: How well will the stock 7M radiator hold up with the 1jz with fmic and 3'' turbo back exhaust? I'm looking at my finances and dont know if I can afford a koyo or not yet.
The Reaper
Jan 10, 2006
1,909
Florida
it will be fine
my boy was pushing close to 500whp on his single 1JZ with stock 7M radiator and 2JZ clutch fan
