What OEM wheels fit our cars?
Doward
4,245
Alachua, FL
Eh.. I'm going down for an alignment today (all the bushings and all look good... the upper arm + balljoint looks new back there in the rear end)
My rear driver side has way too much negative camber. The other 3 tires have worn evenly though.
For some reason, the rears are worn way more than the fronts? :evil2:
Anyway, I've got 2 options within my budget -
Hit the boneyard, find a set of 16x8 wheels off of whatever vehicles you guys list here, and wrap them in my almost new set of 245/50/16s on the Camaro
*or*
Pick up 2 new 225/50/16s for the Sawblades. I've got a u-pull-it here, and I can get a set of 16x8 wheels for a bout $60, and then another $40 for mount/balance = $100
Or, find a set of 225/50/16s (2) and pay more like $150... I'm calling for prices on tires right now.
souprat
fairfax VA
well i think our lug pattern is 5x114.3(big ??).but i do know that rx7(fc and fd) wheels will fit. mustangs. there are a few more i cant think of.
Syris
Need Rust Repair
Aug 24, 2005
687
Bryan, OH /Lima, OH
mustang, camaro, firebird, vette, sc300, quite a lot fit. As long as it is 5x114, but as far as junkyards go the more common cars not totally sure. Also some of the gran prix's and bonnevilles fit
Toyota h8r
Formerly KILLERMK3
Jan 24, 2006
187
Sylvania ohio
I know that camaro/firebird wont fit heres why, chevys use 5x4.75 bolt pattern and mk3`s use 5x4.5 so no dice.
NickSupra
179
tn
Yes, gm lug patterns will not fit our cars. Mustangs, rx7, 300zx,350z,g35,3000gt, yadda yadda. A lot of import manufacturers share the same pattern, be sure to check offset, though. A lot of lexus are almost perfect for our cars. The most compatible wheels are from other toyotas. Camry, avalon, and a few others that slip my mind. Many wheels have similar lug pattern, but these I just mentiones share the same diameter hub mount. This means less stress on the wheel studs and a better, more solid mount.
